HPC/Carbon Cluster - Development tools
From CNM Wiki
< HPC
Revision as of 08:36, May 31, 2011 by Stern (talk | contribs) (→‎OpenMPI)
This is an overview of the compilers and MPI libraries available on Carbon. Each package name leads to its documentation.
See also
Module catalog.
Compilers
GNU family
Intel Software Development Products
As of 2011, we have the following tools under support within the Intel® Composer XE 2011 for Linux bundle.
Documentation is installed locally mainly under:
$ICC_HOME/Documentation
$ ls -F $ICC_HOME/Documentation/en_US
Release_NotesC.pdf  compiler_c/          documentation_f.htm    getting_started_f.pdf  lgpltext
Release_NotesF.pdf  compiler_f/          flicense               idb/                   mkl/
clicense            documentation_c.htm  getting_started_c.pdf  ipp/                   tbb/
No longer maintained on Carbon:
MPI
OpenMPI
This is the primary and recommended MPI version. It supports Ethernet and InfiniBand interconnect, with InfiniBand set as default by means of an OMPI_MCA_… environment variable.
Intel MPI
MPICH/MPICH2
  • Not installed explicitly, but Intel-MPI is based on MPICH2 and provides an MPICH2 runtime environment for precompiled binaries.
