HPC/Carbon Cluster - Development tools
Compilers and development tools
GNU
Intel
We have supported versions of the following commercial tools, currently installed under /opt/intel:
- Fortran
- Manual for 10.1
/opt/intel/{fc,fce}/version
- C++
- Manual for 10.1
/opt/intel/{cc,cce}/version
- Intel Math Kernel Library (MKL), includes Cluster Edition
/opt/intel/mkl/version
- VTune analyzer
- Intel Debugger
/opt/intel/{idb,idbe}/version
To access the documentation pages, use firefox on a login node:
/opt/intel/fce/version/doc/Doc_Index.htm/opt/intel/cce/version/doc/Doc_Index.htm/opt/intel/mkl/version/doc/Doc_index.htm
Note on binary architectures
CPU architecture labels used by Intel and others can be confusing and have changed over time. Here's a summary of the labels and directory names commonly used:
- 32, ia32, x86
- legacy 32-bit x86 generations up to Pentium 4 and Intel Core
- em64t, Intel-64, x86_64, AMD-64
- 64-bit generations of the Xeon branded CPUs, and the Core 2 generation, mostly compatible with AMD's Opteron
- 64, ia64, Itanium
- Itanium – limited ia32 support, but none for x86_64; not used here.
The cce, fce, and idbe directories above provide the 64-bit em64t versions appropriate for the Xeon processors, with ia32 versions being available under cc, fc, idb to compile and run legacy applications. By default, the 64-bit versions are activated in the user's environment ($PATH and others). This is done automatically through /etc/profile.d/{iccvars,ifortvars,mklvarsem64t}.{sh,csh}.
The environment-modules package is used for version and architecture selection.
module list module avail module load ... module unload ... module switch old new
Libraries
Migrated to HPC/Software/Modules/mkl
VTK
PETSc
- TODO: Portable, Extensible Toolkit for Scientific Computation
MPI
OpenMPI
This is the primary and recommended MPI version. It supports Ethernet and Infiniband interconnect.
- See also: FAQ
MPICH/MPIC2
TBD
Intel MPI
Resource Management
- MOAB cluster suite
- Documentation overview
- Torque
- Gold allocation manager
