HPC/Module Setup
< HPC
Introduction
Carbon uses the Environment Modules package to dynamically provision software. The package primarily modifies your $PATH and other environment variables.
To select packages for your use, place module load name
commands near the end of your ~/.bashrc
file.
Shell startup files
- The default login shell on Carbon is bash.
- [t]csh on request, if you absolutely, positively, insist and know what you're doing. (There will be a quiz.) Here are top ten reasons not to use the C shell, and the classic “csh programming considered harmful”. Even though use as login shell may be tangential. It is not supported. It's dead, Jim.
- Place customizations in your file
~/.bashrc
, for example:
# .bashrc # Source global definitions if [ -f /etc/bashrc ]; then . /etc/bashrc fi export PATH=$HOME/mypackage/bin:$PATH module load name1 name2 …
- Note
- In general, do not place a
"module load …"
command in a PBS job script.
- If you must, note that this command will only work for single-node jobs. It will generally fail for multi-node jobs (nodes > 1). The reason is that the job script is only executed (by the
pbs_mom
daemon on your behalf) on the first core on the first node of your request. In general, this environment will be cloned for the other cores on the first node, but not for cores on other nodes. There are flags formpirun
ormpiexec
to pass some or all environment variables to other MPI processes, but these flags are implementation-specific and may not work reliably.
- The recommended way is as above, to place module commands in ~/.bashrc. This might preclude job-specific module sets for conflicting modules or tasks. I'm thinking about a proper solution for this.
Modules – General documentation
$ module help … Usage: module [ switches ] [ subcommand ] [subcommand-args ] … Available SubCommands and Args: + load modulefile [modulefile ...] + unload modulefile [modulefile ...] + switch [modulefile1] modulefile2.] + list + avail [modulefile [modulefile ...]] + whatis [modulefile [modulefile ...]] + help [modulefile [modulefile ...]] + show modulefile [modulefile ..]
For full documentation, consult the manual page:
$ man module
Module Conventions on Carbon
- Most application software is installed under
/opt/soft/
- Package directories are named
name-version-build
, e.g./opt/soft/jmol-12.1.37-1
. - Module names are organized by a mostly version-less name, with the version following after a slash:
name/version-build
. Using thename
alone is possible and will select a default version for a SubCommand to act upon. Some packages carry a major version number in their name, notably fftw3 and vasp5. module help
briefly describes a package and will usually contain a link to its home page.
$ module help jmol ----------- Module Specific Help for 'jmol/12.0.34-1' ------------- Jmol is a molecule viewer platform for researchers in chemistry and biochemistry, implemented in Java for multi-platform use. This is the standalone application. It offers high-performance 3D rendering with no hardware requirements and supports many popular file formats. http://jmol.sourceforge.net/ http://wiki.jmol.org/
- Default modules are loaded by
/etc/profile.d/zz-moduleuse.sh
. (The strange name form ensures this profile segment is loaded last.)
$ module list Currently Loaded Modulefiles: 1) moab/6.0.3-1 4) icc/11/11.1.073 2) gold/2.1.11.0-4 5) ifort/11/11.1.073 3) openmpi/1.4.3-intel11-1 6) mkl/10.2.6.038
Package home directories
Most modules will set a convenience variable NAME_HOME
which points to the toplevel directory. Dashes in the package name are converted to underscores. This is mostly useful to inspect documentation and auxiliary files:
$ module load quantum-espresso $ ls -F $QUANTUM_ESPRESSO_HOME/doc Doc/ atomic_doc/ examples/
- … and to specifcy link paths in makefiles:
$ module load fftw3
LDFLAGS += -L$FFTW3_HOME/lib/
Package-specific sample jobs
Packages that require more than the standard Carbon job template contain a sample job in the toplevel directory:
$ module load quantum-espresso $ cat $QUANTUM_ESPRESSO_HOME/*.job
#!/bin/bash # Job template for Quantum ESPRESSO 4.x on Carbon # #PBS -l nodes=1:ppn=8 #PBS -l walltime=1:00:00 … export ESPRESSO_TMPDIR=$TMPDIR mpirun -x ESPRESSO_TMPDIR \ -machinefile $PBS_NODEFILE \ -np `wc -l < $PBS_NODEFILE` \ pw.x \ < input.txt > output.txt
