HPC/Module Setup
< HPC
Jump to navigation
Jump to search
Shell startup files
- The default login shell on Carbon is bash
- Place customizations in the file
~/.bashrc
# .bashrc # Source global definitions if [ -f /etc/bashrc ]; then . /etc/bashrc fi export PATH=$HOME/mypackage/bin:$PATH module load name1 name2 …
- tcsh only if you insist. It is not supported. In fact: “csh programming considered harmful” – Tom Christiansen
Modules – Introduction
Carbon uses the Environment Modules package to dynamically provision software. The package primarily modifies your $PATH and other environment variables.
Modules general introductions can be found at many other sites, such as:
On Carbon:
$ module help … Usage: module [ switches ] [ subcommand ] [subcommand-args ] … Available SubCommands and Args: + load modulefile [modulefile ...] + unload modulefile [modulefile ...] + switch [modulefile1] modulefile2.] + list + avail [modulefile [modulefile ...]] + whatis [modulefile [modulefile ...]] + help [modulefile [modulefile ...]] + show modulefile [modulefile ..]
For full documentation, consult the manual page:
$ man module
Module Conventions on Carbon
- Most application software is installed under
/opt/soft/
- Packages are located in top-level directories named
name-version-build
, e.g./opt/soft/jmol-12.1.37-1
. - Module names are organized by a mostly version-less name, with the version following after a slash:
name/version-build
. Using thename
alone is possible and will select a default version for a SubCommand to act upon. module help
briefly describes a package and will usually contain a link to its home page.
$ module help jmol ----------- Module Specific Help for 'jmol/12.0.34-1' ------------- Jmol is a molecule viewer platform for researchers in chemistry and biochemistry, implemented in Java for multi-platform use. This is the standalone application. It offers high-performance 3D rendering with no hardware requirements and supports many popular file formats. http://jmol.sourceforge.net/ http://wiki.jmol.org/
- Most modules will set a convenience variable
NAME_HOME
which points to the toplevel directory. This is mostly useful to inspect documentation and auxiliary files:
$ module load jmol $ ls -l $JMOL_HOME/doc total 488 -rw-r--r-- 1 stern stern 369786 Feb 25 12:59 CHANGES.txt -rw-r--r-- 1 stern stern 2841 Feb 25 12:59 COPYRIGHT.txt …
- … and to specifcy link paths in makefiles:
$ module load fftw3
LDFLAGS += -L$FFTW3_HOME/lib/
