HPC/Submitting and Managing Jobs
Directories and Environment
First read: directory configuration.
Applications
We use the environment-modules package to manage user applications.
This is similar to places like NERSC or PNNL.
The basic CNM-specific user environment is configured automatically in /etc/profile.d/cnm.{sh,csh}.
For now the only applications are the Development tools.
Submitting jobs to Moab/Torque
qsub [-A accountname] [options] jobfile
For details on options:
man qsub qsub --help
More details are at the Torque Manual, in particular the qsub man page.
The single main queue is batch and need not be specified. All job routing decisions are handled by the scheduler. In particular, short jobs are accommodated by a daily reserved node and by backfill scheduling, i.e. "waving forward" while a big job waits for full resources to become available.
Debug queue
For testing job processing and your job environment, use qsub -q debug or #PBS -q debug.
The queue accepts jobs under the following conditions
nodes <= 2 ppn <= 4 walltime <= 1:00:00
Checking job status
Use the command qstat (from PBS) or showq (from Moab):
- qstat [-u $USER]
- showq [-u $USER]
- regular output
- qstat -a
- showq -n
- alternate format (showing job names)
Getting extra information
- qstat -n [-1] jobnum
- Show nodes where a job runs.
- qstat -f [jobnum] [-1]
- Full information such as submit arguments and run directories. The "-1" option disables wrapping for long output lines.
- checkjob [-v] jobnum
- Get extended jobs status information – useful to diagnose problems with "stuck" jobs.
Removing jobs
To retract a queued job or terminate an already running job:
qdel jobnumber
Example job file
- sample job file for Infiniband interconnect (recommended):
#!/bin/bash
## Basics: Number of nodes, processors per node (ppn), and walltime (hhh:mm:ss)
#PBS -l nodes=5:ppn=8
#PBS -l walltime=0:10:00
#PBS -N job_name
#PBS -A account
## File names for stdout and stderr. If not set here, the defaults
## are <JOBNAME>.o<JOBNUM> and <JOBNAME>.e<JOBNUM>
#PBS -o job.out
#PBS -e job.err
## send mail at begin, end, abort, or never (b, e, a, n)
#PBS -m ea
# change into the directory where qsub will be executed
cd $PBS_O_WORKDIR
# count allocated cores
NPROCS=`wc -l < $PBS_NODEFILE`
# start MPI job over default interconnect
mpirun -machinefile $PBS_NODEFILE -np $NPROCS \
programname
- If your program reads from files or takes options and/or arguments, use and adjust one of the following forms
programname < run.in
programname -options arguments < run.in
programname < run.in > run.out 2> run.err
- In this form, anything after
programnameis optional. If you use specific redirections for stdout or stderr as shown (>, 2>), the job-global filesjob.out, job.errdeclared earlier will remain empty or only contain output from your shell startup files (which should really be silent), and the rest of your job script.
- Infiniband (OpenIB) is the default (and fast) interconnect mechanism for MPI jobs. This is configured through the environment variable
$OMPI_MCA_btl. - To select ethernet transport (e.g. for embarrasingly parallel jobs), specify an
-mcaoption:
-mca btl self,tcp \
programname
The account parameter
The parameter for option -A account is in most cases the CNM proposal, specified as follows:
cnm123- (3 digits) for proposals below 1000
cnm01234- (5 digits, 0-padded) for proposals from 1000 onwards.
user- (the actual string "user", not your user name) for a limited personal startup allocation
staff- for discretionary access by staff.
You can check your account balance in hours as follows:
mybalance -h gbalance -u $USER -h
Node Types
Hardware
Carbon has two major node types, called gen1 and gen2, and gen2 is further differentiated by the amount of memory.
| Node names, types |
Node generation |
Node extra properties |
Node count |
Cores per node (max. ppn)
Cores total, by type |
Account charge rate |
CPU model |
CPUs per node |
CPU nominal clock (GHz) |
Mem. per node (GB) |
Mem. per core (GB) |
GPU model |
GPU per node |
VRAM per GPU (GB) |
Disk per node (GB) |
Year added |
Note |
| Login | |||||||||||||||||
| login5…6 | gen7a | gpus=2 | 2 | 16 | 32 | 1.0 | Xeon Silver 4125 | 2 | 2.50 | 192 | 12 | Tesla V100 | 2 | 32 | 250 | 2019 | |
| Compute | |||||||||||||||||
| n421…460 | gen5 | 40 | 16 | 640 | 1.0 | Xeon E5-2650 v4 | 2 | 2.10 | 128 | 8 | 250 | 2017 | |||||
| n461…476 | gen6 | 16 | 16 | 256 | 1.0 | Xeon Silver 4110 | 2 | 2.10 | 96 | 6 | 1000 | 2018 | |||||
| n477…512 | gen6 | 36 | 16 | 576 | 1.0 | Xeon Silver 4110 | 2 | 2.10 | 192 | 12 | 1000 | 2018 | |||||
| n513…534 | gen7 | gpus=2 | 22 | 32 | 704 | 1.5 | Xeon Gold 6226R | 2 | 2.90 | 192 | 6 | Tesla V100S | 2 | 32 | 250 | 2020 | |
| n541…580 | gen8 | 20 | 64 | 2560 | 1.0 | Xeon Gold 6430 | 2 | 2.10 | 1024 | 16 | 420 | 2024 | |||||
| Total | 134 | 4736 | 48 | ||||||||||||||
Benchmarks show that gen2 nodes are about twice as fast as gen1 nodes for memory-intensive applications. (The X5300 series is hampered by a memory bandwidth bottleneck when all 8 cores are active and frequently access memory.) Thus, gen1 nodes are charged at a discounted rate of 50% of the walltime actually used.
Selecting node types for jobs
Jobs are directed automatically onto either gen1 or gen2 nodes, with preference for gen2 if both are available. Unless specifically requested, jobs will never mix generations. This will avoid disparate CPU speeds and MPI communication setup in a job. You can force jobs onto either node set in the job script after #PBS or on the qsub command line by suffixing the nodes= specifier with a property such as :gen1 or :gen2. For example, to run on 2 nodes with 8 cores each:
qsub -l nodes=2:ppn=8:gen1 foo.job (not recommended for VASP)
qsub -l nodes=2:ppn=8:gen2 foo.job
The following are (as of now) equivalent, since "bigmem" currently implies "gen2":
qsub -l nodes=2:ppn=8:gen2:bigmem foo.job
qsub -l nodes=2:ppn=8:bigmem foo.job
See also:
http://www.clusterresources.com/torquedocs21/2.1jobsubmission.shtml#resources
PPN Tricks
Each Carbon node has 8 cores, and for many jobs users indeed request entire nodes by specififying ppn=8 in the job submission.
However, you may need to request fewer cores, e.g. for the following reasons:
- your application is not parallelized,
- your application has limited hardcoded parallelization, e.g. for 2 or 4 cores only,
- your application runs multi-threaded but uses
$PBS_NODEFILE to infer the number of processes to start,
- your application runs busy service processes or service threads (e.g. NWChem),
- your application saturates a resource, e.g. memory bandwidth (some large VASP calculations),
- the node's memory is exhausted by fewer application processeses than there are cores available.
Depending on the reason, the node either may be or must not be used by other jobs.
In the past, the only way to achieve exclusive but undersubscribed node access was to request ppn=8 and then to thin out a copy of the nodefile before passing it to the application.
To eliminate the need to edit the nodefile, use the -l naccesspolicy=… flag to differentiate between resources requested from PBS from those passed to the application.
Select an option from the following scenarios.
- General node sharing
- When a job requires only a few cores and a commensurate fraction of other resources, simply specify
ppn as needed:
#PBS -l nodes=nnn:ppn=4
- In this case, the remaining cores may be allocated to other jobs, which is the default policy:
#PBS -l naccesspolicy=SHARED
- User-specific node sharing
- To permit node sharing among your own jobs, specify a SINGLEUSER policy:
#PBS -l nodes=nnn:ppn=2
#PBS -l naccesspolicy=SINGLEUSER
- Exclusive node access
- When your job requires only a few cores but a disproportionate fraction of another resource on a node (such as most of its memory or a lot of I/O bandwidth), claim the entire node:
#PBS -l naccesspolicy=SINGLEJOB
- PBS will reserve the entire node(s), but place each node name only
ppn times in the $PBS_NODEFILE.
Different PPN by node
- When your first MPI process (the "master" process) requires more memory than your other "worker" processes, give several
nodes specifications, separated by a "+" character (which is unusal and born of historical necessity):
#PBS -l nodes=1:ppn=1+2:ppn=4
- For clarity, the
nodes specification in this example reads as follows:
nodes = ( 1:ppn=1 ) + ( 2:ppn=4 )
- This will request 3 node exclusively, but the first node will occur only once in the
$PBS_NODEFILE, e.g.
n011
n012
n012
n012
n012
n034
n034
n034
n034
In all of the preceding scenarios the following applies:
- The
$PBS_NODEFILE seen by the job script will always match ppn.
- For accounting, the job will be billed by the number of cores blocked from use by other users, i.e.,
ncores=ppn for shared nodes, and ncores=8 otherwise.
Multithreading (OpenMP)
When you wish to use multithreading, you must ensure that the total number of "busy" user threads and processes corresponds to the number of cores requested from PBS. Today, multithreading in applications and libraries is typically programmed using the OpenMP interface and the number of threads is controlled by the environment variable $OMP_NUM_THREADS.
Select from the following scenarios.
- OpenMP, single entire node
#PBS -l nodes=1:ppn=8
cd $PBS_O_WORKDIR
export OMP_NUM_THREADS=8
- OpenMP, single node, possibly shared
- choose the number of cores
n such that 1 ≤ n ≤ 8:
#PBS -l nodes=1:ppn=n
cd $PBS_O_WORKDIR
export OMP_NUM_THREADS=`uniq -c $PBS_NODEFILE | awk '{print $1; exit}'`
- Here, the default policy "SHARED" is in effect, and OMP_NUM_THREADS is set automatically by counting the number of times that the first node occurs in
$PBS_NODEFILE. This will allow you to vary or override the nodes setting using "qsub -l nodes=…" without having to edit it twice in the job file.
- OpenMP/MPI hybrid
- Making efficient use of multithreading on multiple nodes which communicate over MPI is fairly involved and is subject to ongoing research. PBS requests are the same as in the preceding case (OpenMP only), but you must export
OMP_NUM_THREADS to all MPI satellite nodes. Further, since $PBS_NODEFILE is typically used to identify remote nodes, you must thin out the file before using it as machinefile:
#!/bin/bash
#PBS -l nodes=nnn:ppn=8
MACHINEFILE=$PBS_NODEFILE
if [ multithreaded ] # insert specific condition
then
MACHINEFILE=machinefile
sort -u $PBS_NODEFILE > $MACHINEFILE
fi
mpirun -x OMP_NUM_THREADS=`uniq -c $PBS_NODEFILE | awk '{print $1; exit}'` \
-machinefile $MACHINEFILE \
-np `wc -l < $MACHINEFILE` \
The -x option is specific to OpenMPI; please consult the documentation to achieve the same behavior in other MPI implementations.
Interactive node access
- You can use
ssh to interactively access any compute node on which a job of yours is running. As soon as a node no longer runs at least one of your jobs, your ssh session to that node will be terminated.
