HPC/Submitting and Managing Jobs
Directories and Environment
First read: directory configuration.
Applications
We use the environment-modules package to manage user applications.
This is similar to places like NERSC or PNNL.
The basic CNM-specific user environment is configured automatically in /etc/profile.d/cnm.{sh,csh}.
For now the only applications are the Development tools.
Admin note: The master copy of these files resides in mgmt{01,02}:/opt/teamhpc/node-skel/etc/profile.d and is distributed by ~root/bin/skeldistrib.
Submitting jobs to Moab/Torque
qsub [-A accountname] [options] jobfile
For details on options:
man qsub qsub --help # sorry, not much)
We currently have only the default queue configured.
More details at the Torque Wiki, in particular the full qsub documentation for all supported PBS options.
Querying jobs
Use the command qstat (from PBS) or showq (from Moab):
- qstat [-u $USER]
- showq [-u $USER]
- regular output
- qstat -a
- showq -n
- alternate format (showing names)
- qstat -f [jobnum]
- full information
- checkjob [-v] jobnum
- get extended jobs status information – useful to diagnose problems with "stuck" jobs.
Removing jobs
qdel jobnumber
Example job file
- sample job file for Infiniband interconnect (recommended):
#!/bin/bash
## Basics: Number of nodes, processors per node (ppn), and walltime (hhh:mm:ss)
#PBS -l nodes=5:ppn=8
#PBS -l walltime=0:10:00
#PBS -N job_name
#PBS -A account
## File names for stdout and stderr. If not set here, the defaults
## are <JOBNAME>.o<JOBNUM> and <JOBNAME>.e<JOBNUM>
#PBS -o job.out
#PBS -e job.err
## send mail at begin, end, abort, or never (b, e, a, n)
#PBS -m ea
# change into the directory where qsub will be executed
cd $PBS_O_WORKDIR
# count allocated cores
NPROCS=`wc -l < $PBS_NODEFILE`
# start MPI job over default interconnect
mpirun -machinefile $PBS_NODEFILE -np $NPROCS \
programname
- If your program reads from files or takes options and/or arguments, use and adjust one of the following forms
programname < run.in
programname -options arguments < run.in
programname < run.in > run.out 2> run.err
- In this form, anything after
programnameis optional. If you use specific redirections for stdout or stderr as shown (>, 2>), the job-global filesjob.out, job.errdeclared earlier will remain empty or only contain output from your shell startup files (which should really be silent), and the rest of your job script.
- Infiniband (OpenIB) is the default (and fast) interconnect mechanism for MPI jobs. This is configured through the environment variable
$OMPI_MCA_btl. - To select ethernet transport (e.g. for embarrasingly parallel jobs), specify an
-mcaoption:
-mca btl self,tcp \
programname
The account parameter
The parameter for option -A account is in most cases the CNM proposal, specified as follows:
cnm123- (3 digits) for proposals below 1000
cnm01234- (5 digits, 0-padded) for proposals from 1000 onwards.
user- for a limited personal startup allocation
staff- for discretionary access by staff.
You can check your account balance in hours as follows:
mybalance -h gbalance -u $USER -h
Using OpenMP
For hybrid MPI/OpenMP operation under PBS (which is what happens when linking the MKL with OpenMP), two adjustments are necessary:
- The environment variable
OMP_NUM_THREADSneeds to be set to the number of available cores per node, i.e., the ppn parameter. By default, this variable is set to 1 to select single-threading of OpenMP-compiled applications. - The machinefile needs to be thinned out in the job file, to have each node listed only once.
Example
#!/bin/bash
#PBS -l nodes=nnn:ppn=8
MACHINEFILE=$PBS_NODEFILE
if [ multithreaded ] # insert specific condition
then
sort -u $MACHINEFILE > machinefile
MACHINEFILE=machinefile
export OMP_NUM_THREADS=8
fi
NPROC=`wc -l < $MACHINEFILE`
Hybrid MPI+OpenMP is currently unsupported and may well be less efficient than compiling and running with MPI-only communication.
Policies
- Direct user access to nodes is only possible while a job is running for that user. This is governed by the torque-pam package.
