HPC/Sharing Files
From CNM Wiki
< HPC
Revision as of 20:53, February 24, 2010 by Stern (talk | contribs) (Using a /tmp directory: demote)
Introduction
When you collaborate with other users on a common project on Carbon, you may wish to share files among you. There are several ways to achieve this, largely distinguished by how often and for how long sharing is needed.
Sharing Types
Using a Unix group
The system admin can create a Unix group for you.
  • suitable for ongoing exchanges
  • a matching group directory will be located in /home/share/groupname/
  • mutually writable among members, without concessions to other users
  • permissions are inherited for all files placed there
To "project group" request the creation of a group, please send the following information:
  • a short (up to some 8 chars) group name
  • the user list (later changes are easy)
Sharing in your own directories
You can give access to some your directories in your respective $HOME or $SANDBOX by opening permissions.
  • typically one-way (unless you grant world-write)
  • likely to need chmod whenever more files are placed.
You can arrange this on your own as follows:
Owner
chmod a+x $HOME/
mkdir $HOME/share
# populate ..
chmod -R a+rX $HOME/share
Reader
cd /home/owner/share
ls
cp -p ....
If you have particularly largefiles, replace $HOME and /home by $SANDBOX and /sandbox, respectively.
  • suitable for one-off exchanges
  • typically fairly loose permissions
  • resides on only one host
  • world-write not recommended
You can arrange this on your own as well:
mkdir /tmp/foo
# populate ..
chmod -R a+rX /tmp/foo
