HPC/Submitting and Managing Jobs
Environment configuration
Home dir
The users' home directories are hosted on lustre and are backed up nightly. The home directory can be reached, in standard Unix fashion using either of the two following symbols:
~ $HOME
lustre sandbox
For files that need to be shared among the nodes, and are possibly large and change often, use a "sandbox" directory.
The environment variable $SANDBOX points to such a user-specific directory, which is shared by lustre, but not backed up.
lustre is a parallel file system that allows concurrent and coherent file access at high data rates.
Applications
In the final configuration, we will use the environment-modules package to manage user applications. This will be similar to places like NERSC or PNNL. In early access mode, the CNM-specific user environment is configured automatically in /etc/profile.d/cnm.{sh,csh}.
For now the only applications are the Development tools.
Admin note: The master copy of these files resides in mgmt{01,02}:/opt/teamhpc/node-skel/etc/profile.d and is distributed by ~root/bin/skeldistrib.
Submitting jobs to Moab/Torque
qsub [options] jobfile
For details on options:
man qsub qsub --help # sorry, not much)
We currently have only the default queue configured.
More details at the Torque Wiki, in particular the full qsub documentation for all supported PBS options.
Querying jobs
Use the qstat command
- qstat
- regular output
- qstat -a
- alternate format
- qstat -f
- full information
Removing jobs
qdel jobnumber
Example job file
- sample job file for Infiniband interconnect (recommended):
#!/bin/bash
## Basics: Number of nodes, processors per node (ppn), and walltime (hhh:mm:ss)
#PBS -l nodes=5:ppn=8
#PBS -l walltime=0:10:00
#PBS -N job_name
## redirect stdout and stderr
#PBS -o job.out
#PBS -e job.err
## send mail at begin, end, abort, or never (b, e, a, n)
#PBS -m ea
# change directory
cd $PBS_O_WORKDIR
# set $NPROCS to the count of allocated cores
NPROCS=`wc -l < $PBS_NODEFILE`
# Verbose info, may be removed
cat << END_INFO
master node: `hostname`
working directory: `pwd`
nodes file: $PBS_NODEFILE
number of processes: $NPROCS
process list: `cat $PBS_NODEFILE`
END_INFO
# start MPI job over Infiniband transport
mpirun -machinefile $PBS_NODEFILE -np $NPROCS \
programname
- Update 2009-02-24
OpenIB is now the default, set in the environment variable OMPI_MCA_btl.
- To select ethernet transport (e.g. for embarrasingly parallel jobs), simply omit the
-mca options:
-mca btl self,tcp \
programname
Using OpenMP
For hybrid MPI/OpenMP operation under PBS (which is what happens when linking the MKL with OpenMP), two adjustments are necessary:
- The environment variable
OMP_NUM_THREADSneeds to be set to the number of available cores per node, i.e., the ppn parameter. By default, this variable is set to 1 to select single-threading of OpenMP-compiled applications. - The machinefile needs to be thinned out in the job file, to have each node listed only once.
Example
#!/bin/bash
#PBS -l nodes=nnn:ppn=8
MACHINEFILE=$PBS_NODEFILE
if [ multithreaded ] # insert specific condition
then
sort -u $MACHINEFILE > machinefile
MACHINEFILE=machinefile
export OMP_NUM_THREADS=8
fi
NPROC=`wc -l < $MACHINEFILE`
Hybrid MPI+OpenMP is currently unsupported and may well be less efficient than compiling and running with MPI-only communication.
Policies
- Direct user access to nodes is only possible while a job is running for that user. This is governed by the torque-pam package.
- When attempting to schedule a job that used 5 nodes and 1 cpu per node (for a total of 5 cpus), Moab's default policy was to pack all of those jobs onto as few nodes as possible. Thus it was putting the job on 5 cores of the same node. This is usually not desired behavior, so I set a new parameter in /opt/moab/moab.cfg: "JOBNODEMATCHPOLICY EXACTNODE". Now jobs are allocated to nodes exactly as users request. [to be reviewed - stern]
-- Mail from W. Dinkel, Oct. 31
