Plotting macros
Back to X-Ray Microscopy
| command | description |
| setplot [mode] | Select plotting options |
| plot | Plot data on printer |
| rplot | Plot updated data at each point of scan |
| splot | Plot data on screen |
| pts | List current data on the screen |
| lp_plot | Primitive 132-column wide plot for printers |
| wa | Show positions of all motors |
| lm | Show limits of all motors |
| plot_res | Show results after scans |
| splot_res | Show results on screen plot |
| rplot_res | Show results on updated plot during scans |
The setplot macro assigns values to the global variable, PLOT_MODE, according to the values defined in the following table:
| bit value | description |
| 1 | Do updated plotting during scans |
| 2 | Do screen plot after scan |
| 4 | Do printer plot after scan |
| 8 | Scale x-axis of screen plots to fit width of scan |
| 16 | Force y-axis minimum to be zero |
| 32 | Use logarithmic y-axis |
| 64 | Do simple background subtraction |
| 128 | Use high-resolution plotting device |
| 256 | With high-res, don't use large dots |
| 512 | With high-res, don't connect points with lines |
| 1024 | With high-res, don't draw error bars |
