HPC/Carbon Cluster - Development tools
From CNM Wiki
< HPC
Revision as of 15:54, April 8, 2009 by Stern (talk | contribs) (category)
Compilers and development tools
GNU
Intel
We have supported versions of the following commercial tools, currently installed under /opt/intel:
To access the documentation pages, use firefox on a login node:
  • /opt/intel/fce/version/doc/Doc_Index.htm
  • /opt/intel/cce/version/doc/Doc_Index.htm
  • /opt/intel/mkl/version/doc/Doc_index.htm
Note on binary architectures
CPU architecture labels used by Intel and others can be confusing and have changed over time. Here's a summary of the labels and directory names commonly used:
32, ia32, x86
legacy 32-bit x86 generations up to Pentium 4 and Intel Core
em64t, Intel-64, x86_64, AMD-64
64-bit generations of the Xeon branded CPUs, and the Core 2 generation, mostly compatible with AMD's Opteron
64, ia64, Itanium
Itanium – limited ia32 support, but none for x86_64; not used here.
The cce, fce, and idbe directories above provide the 64-bit em64t versions appropriate for the Xeon processors, with ia32 versions being available under cc, fc, idb to compile and run legacy applications. By default, the 64-bit versions are activated in the user's environment ($PATH and others). This is done automatically through /etc/profile.d/{iccvars,ifortvars,mklvarsem64t}.{sh,csh}.
In the future, we will leverage the environment-modules package for version and architecture selection.
Libraries
Intel Math Kernel Library (MKL)
User Notes
 # Sequential:
   -lmkl_intel_lp64 -lmkl_sequential -lmkl_core -lpthread
 # OpenMP multi-threaded:
   -lmkl_intel_lp64 -lmkl_intel_thread -lmkl_core -liomp5 -lpthread
  • The FFTW interface of the MKL can be linked by prefixing the above options with one of:
-lfftw2xc_intel
-lfftw2xf_intel
-lfftw3xc_intel
-lfftw3xf_intel
Choose the appropriate version between bindings for FFTW v2 vs. v3 and C vs. Fortran.
  • Avoid specifying absolute library paths in your Makefile unless you wish to select a specific version. The user environment is normally correctly set up. To force the library version current at the time of writing, add as first flag to the linker options:
-L$MKLROOT/lib/em64t. The variable $MKLROOTis automatically provided.
VTK
PETSc
  • TODO: Portable, Extensible Toolkit for Scientific Computation
MPI
OpenMPI
This is the primary and recommended MPI version. It supports Ethernet and Infiniband interconnect.
MPICH/MPIC2
TBD
Intel MPI
Resource Management
(description of overlap/differences)
