Main Page
From ATLAS Accelerator In-Flight Beam Program
Revision as of 15:51, June 14, 2019 by Ttang (talk | contribs) (BoxScore)
Landing Page for the ATLAS In-Flight Beam Wiki
The goal of this wiki is to have access to detector (locations, status, etc.), electronics, hardware, software, targets, and misc, information pertaining to in-flight beam production. The actual data collection and analysis information can be found on the ELOG.
Tools for In-Flight Beam Tuning
Experiment List
  • infl1 - 19O commissioning [Jul / Aug 18]
  • infl2 - 16C development [Aug / Oct 18]
  • infl3 - 30P development [Oct 18]
  • infl4 - 16C delivered to MUSIC / SPS [Dec 2018, Feb 2019]
  • infl5 - 30P delivered to Gretina/FMA/GODDESS [Feb/March 2019]
  • infl6 - 12B delivery to HELIOS [Apr/May 2019]
  • infl7 - 8Li delivery to HELIOS [May/June 2019]
  • infl8 - 29Al,31Si development [June 2019]
  • infl9 - 31Si to HELIOS ATLAS 1830 Wilson [June 2019]
new exp template
Hardware Information
Computers
- diag1, diag2, diag3, all on onenet running UBUNTU 18
Digitizers
- dig1, dig2
If you are either not familiar with the MediaWiki collaboration platform or have never edited this wiki before, please visit the Help page. In order to edit this wiki you must first log in.
BoxScore
BoxScore is a custom made cpp program for "almost" real-time monitoring.
github : https://github.com/goluckyryan/RealTimeReading
program required libaray
CAENComm.h
CAENVMElib.h
CAENDigitizer.h
cern root
program arugments
/BoxScore boardID Location (save_file_name)
                    |-- exit
                    |-- cross
                    |-- ZD (zero-degree)
The boardID can be checked by running DetectDigitizer
program running flow
The source code is src/BoxScore.c
  1. When started, it read the current date and time from the system, and format the default save_file_name.
  2. Based on which Location, it will make a ChannelMask and set the dE and E channels.
  3. Read the generalSetting.txt
  4. Read setting_X.txt for Channel X setting
  5. Open digitizer and setting digitizer from the setting
  6. Make root file for saving the data and histogram, Make Canvas for display
  7. Readout Loop
    1. check keyboard is hit, get keyboard hit
    2. if start acquisition
      1. retrieve data from the digitizer
      2. every 1 sec (the time period can be set at generalSetting.txt), sorting event based on timestamp, and build event
Grafana + InfluxDB
Current setting on June 14, 2019
When BoxScore is running at diag1, it will push the totalRate and (if any) cuts rates to the InfluxDB service at diag1 using
void WriteToDataBase(TString databaseName, TString seriesName, TString tag, float value){
   TString databaseStr;
   databaseStr.Form("influx -execute \'insert %s,%s value=%f\' -database=%s", seriesName.Data(), tag.Data(), value, databaseName.Data());
   system(databaseStr.Data());
The databaseName = RAISOR_exit
The seriseName = totalRate / cut1 / cut2 .... etc
The tag = exit / cross / ZD
InfluxDB
InfluxDB server is hosted at diag1.
InfluxDB server can be access via port 8086.
If the InfluxDB server is not started, it can be started by
sudo service influxdb start
Grafana
The Grafana server is hosted at diag3.
The Grafana webpage can be access using any browser
http://diag3.onenet:3000
The login user name is admin, password is the same as diag3 login.
if the server not started (for example, the webpage is not loaded but connection to diag3 is ok.) it can be started by
sudo service grafana-server start
