Infl8
From ATLAS Accelerator In-Flight Beam Program
Revision as of 02:42, June 8, 2019 by Crhoffman (talk | contribs) (29Al==)
(diff) ← Older revision | Latest revision (diff) | Newer revision → (diff)
General Info
Secondary Beam(s)
  • 29Al13+, 31Si14+
  • Energy: ~10 MeV/u for each
  • Requested rate and purity: 5x104 pps, >10 %
  • Achieved rate (pps/pnA):
    • [June 19] (XXX pps/pnA) [XXX pnA XXXXXX]
  • Purity:
    • [June 19] XXX% best
Tuning Info
Primary Beam (energy) [max pnA]
  • 30Si?? [11.5 MeV/u, 345 MeV][120 / 50 pnA]
  • Target 1: 4 mg/cm2 Be (29Al13+)
  • Target 2: 12 mg/cm2 Be (29Al13+) --> if time
  • Target 3: D2 Gas w/ 1.9 mg/cm2 HAVAR windows (3.7 cm, 1400 mbarr, T=90K) [31Si14+]
=========29Al===========
29Al - 4 mg/cm2 target
Beam Label Energy [MeV] Brho [Tm] calc / TOF Scale Factor DE-E (50 / 1000 um) DE-E (150 / 1000) Target
30Si??+ primary 345 XXX calc 71 / 273 MeV 273 / 71 MeV none
30Si14+ degraded 319.8 1.009 tof 76 / 244 MeV 305 / ~14 MeV 4 mg/cm2 Be
29Al13+ secondary 307.4 1.04767 calc 3.8% 66 / 241 MeV 256 / 51 MeV 4 mg/cm2 Be
30Si13+ contam 297 1.04767 calc 80 / 217 MeV 217 / 0 MeV 4 mg/cm2 Be
  • Scale Factor:
    • [June 19] 29Al13+ [307.4 MeV] from 30Si14+ [319.8 MeV] scale factor = 1.04767/1.009 = 1.038
  • Expected calculated rates for tuning (acceptable - ideal):
    • At EXIT Detector: >250-1000 pps/pnA (midplane slits set to ~+-4 mm, ~3% momentum acceptance).
    • At HELIOS Cross Detector: >70-250 pps/pnA (assumes ~25% transmission, maybe on the high side...)
=========31Si===========
31Si - D2 gas target
30Si14+ degraded 301.2 0.9791 calc 79 / 222 MeV 301.2 / ~0 MeV D2 Gas
31Si14+ secondary 301.3 0.9944 calc 1.6% 81 / 219 MeV 301.3 / ~0 MeV D2 Gas
30Si13+ contam 267.7 0.9944 calc 87 / 181 MeV 267.7 / 0 MeV D2 Gas
  • Scale Factor:
    • [June 19] 31Si14+ [301.3 MeV] from 31Si14+ [301.2 MeV] scale factor = 0.9944/0.9791 = 1.0156
    • At EXIT Detector: >5000-10000 pps/pnA (midplane slits set to ~+-4 mm, ~3% momentum acceptance).
    • At HELIOS Cross Detector: >1000-2000 pps/pnA (assumes ~20% transmission, maybe on the high side...)
