Infl8
General Info
- RAISOR Devel
- [June 19]
- 29Al, 31Si
- Location in in-flight ELOG
- @ HOMEPLATE and possibly SHORTSTOP
Secondary Beam(s)
- 29Al13+, 31Si14+
- Energy: ~10 MeV/u for each
- Requested rate and purity: 5x104 pps, >10 %
- Achieved rate (pps/pnA):
- [June 19] (XXX pps/pnA) [XXX pnA XXXXXX]
- Purity:
- [June 19] XXX% best
Tuning Info
Primary Beam (energy) [max pnA]
- 30Si?? [11.5 MeV/u, 345 MeV][120 / 50 pnA]
- Target 1: 4 mg/cm2 Be (29Al13+)
- Target 2: 12 mg/cm2 Be (29Al13+)
- Target 3: D2 Gas w/ 1.9 mg/cm2 HAVAR windows (3.7 cm, 1400 mbarr, T=90K) [31Si14+]
29Al
Beam | Label | Energy [MeV] | Brho [Tm] | calc / TOF | Scale Factor | DE-E (50 / 1000 um) | DE-E (150 / 1000) | Target |
30Si??+ | primary | 345 | XXX | TOF | XXX / XXX MeV | XXX / XXX MeV | XXX | |
30Si??+ | degraded | 345 | XXX | TOF | XXX / XXX MeV | XXX / XXX MeV | 4 mg/cm2 Be | |
B5+ | secondary | 89 | 0.90318 | TOF | 12.5 / 76 MeV | 44 / 45 MeV | 4 mg/cm2 Be | |
12B5+ | degraded | 86.8 | 0.9316 | calc | 3.14% | 13.7 / 73 MeV | 49 / 37 MeV | 12 mg/cm2 Be |
11B4+ | secondary | 60.7 | 0.9316 | calc | 17.5 / 43 MeV | 60.7 / 0 MeV | 12 mg/cm2 Be |
- Scale Factor:
- [Date 19] 12B5+ [86.8 MeV] from 11B5+ [89 MeV] scale factor = 0.9316/0.90318 = 0.0314
- Expected calculated rates for tuning (acceptable - ideal):
- At EXIT Detector: >12000-14000 pps/pnA (midplane slits set to ~+-4 mm, ~3% momentum acceptance).
- At HELIOS Cross Detector: >5000-6000 pps/pnA (assumes ~40% transmission, maybe on the high side...)
31Si
30Si??+ | degraded | 345 | XXX | TOF | XXX / XXX MeV | XXX / XXX MeV | XXX | |
12B5+ | secondary | 86.8 | 0.9316 | calc | 3.14% | 13.7 / 73 MeV | 49 / 37 MeV | 12 mg/cm2 Be |
11B4+ | secondary | 60.7 | 0.9316 | calc | 17.5 / 43 MeV | 60.7 / 0 MeV | D2 gas |
- Scale Factor:
