General Info
Secondary Beam(s)
- 29Al13+, 31Si14+
- Energy: ~10 MeV/u for each
- Requested rate and purity: 5x104 pps, >10 %
- Achieved rate (pps/pnA):
- [June 19] (XXX pps/pnA) [XXX pnA XXXXXX]
- Purity:
Tuning Info
Primary Beam (energy) [max pnA]
- 30Si?? [11.5 MeV/u, 345 MeV][120 / 50 pnA]
- Target 1: 4 mg/cm2 Be (29Al13+)
- Target 2: 12 mg/cm2 Be (29Al13+)
- Target 3: D2 Gas w/ 1.9 mg/cm2 HAVAR windows (3.7 cm, 1400 mbarr, T=90K) [31Si14+]
Beam |
Label |
Energy [MeV] |
Brho [Tm] |
calc / TOF |
Scale Factor |
DE-E (50 / 1000 um) |
DE-E (150 / 1000) |
Target
30Si??+ |
primary |
345 |
XXX |
TOF |
XXX / XXX MeV |
XXX / XXX MeV |
XXX
30Si??+ |
degraded |
345 |
XXX |
TOF |
XXX / XXX MeV |
XXX / XXX MeV |
4 mg/cm2 Be
B5+ |
secondary |
89 |
0.90318 |
TOF |
12.5 / 76 MeV |
44 / 45 MeV |
4 mg/cm2 Be
12B5+ |
degraded |
86.8 |
0.9316 |
calc |
3.14% |
13.7 / 73 MeV |
49 / 37 MeV |
12 mg/cm2 Be
11B4+ |
secondary |
60.7 |
0.9316 |
calc |
17.5 / 43 MeV |
60.7 / 0 MeV |
12 mg/cm2 Be
- Scale Factor:
- [Date 19] 12B5+ [86.8 MeV] from 11B5+ [89 MeV] scale factor = 0.9316/0.90318 = 0.0314
- Expected calculated rates for tuning (acceptable - ideal):
- At EXIT Detector: >12000-14000 pps/pnA (midplane slits set to ~+-4 mm, ~3% momentum acceptance).
- At HELIOS Cross Detector: >5000-6000 pps/pnA (assumes ~40% transmission, maybe on the high side...)
Beam |
Label |
Energy [MeV] |
Brho [Tm] |
calc / TOF |
Scale Factor |
DE-E (150 / 1000) |
Target
30Si??+ |
primary |
345 |
XXX |
TOF |
XXX / XXX MeV |
XXX / XXX MeV |
XXX
30Si??+ |
degraded |
345 |
XXX |
TOF |
XXX / XXX MeV |
XXX / XXX MeV |
XXX
B5+ |
secondary |
89 |
0.90318 |
TOF |
12.5 / 76 MeV |
44 / 45 MeV |
4 mg/cm2 Be
12B5+ |
secondary |
86.8 |
0.9316 |
calc |
3.14% |
13.7 / 73 MeV |
49 / 37 MeV |
12 mg/cm2 Be
11B4+ |
secondary |
60.7 |
0.9316 |
calc |
17.5 / 43 MeV |
60.7 / 0 MeV |
D2 gas
- Scale Factor:
